G
geller
Hi guys.
Simple query here.
My Nan has just moved to a new bungalow and there is a problem with the cooker.
It sometimes trips the rcd in the Consumer unit. Not every time she uses it, but occasionally.
I looked at the fuses and the cooker is wired to a 32 amp breaker.
Is this right ? as i thought it should be a 45 amp ?
It has recently been rewired and the electrics look OK to me (not a sparks).
I just need to know if i should change the mcb to a higher rated one or not ?
Thanks.
Simple query here.
Thanks.
