Cooker points | on ElectriciansForums
Discuss Cooker points in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
When wiring a cooker point and the hot plate and oven come with 2.5mm flex on each am I right in saying you can just wire into the 6mm outlet plate??? I'm sure you can.. Is there a reg that relates to this... If you can help thanks..
firstly do you look at the rating of the cooker/ oven/hob, whatever you are considering connecting?
Ok I know can get dual plate , what i should be asking and you've forced me into the real question about connecting 2.5mm on to 32A mcb/Rcbo ..but as I see it should be fused down or change flex too 4mm which I've done in past,but I've read on forum before that it's fine
I doubt it is 2.5mm2, cookers are usually wired in tri-rated
Reply to Cooker points in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Have never used anything else. Room to dress 2 x 10mm2 T&E properly. Both flush metal boxes and surface boxes are available.
