cooker rating | on ElectriciansForums
Discuss cooker rating in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
i have just bought a range cooker that is dual fuel, its mostly gas but has an electric hob/warmer, in the specs it says the max load is 7.2kw but it has a plug top? i need to put a socket in for it but not sure if i can use the existing wiring and downrate the mcb?
Rob
Something does not ring true.
You cannot run 7300 watts on a 13a plug top.
This will need direct connection on a separate circuit.
Normally run in 6mm cable.
are you sure the plug top is not for the spark to light the gas?
there is only a plug top, no plate for a fixed connection, the electrical side of it is only ignition and a small hob/plate heater so i would assume it doesnt pull much ampage, just referring to the literature that came with it says max load @ 230v 7.2 kw, which has me a bit confused
Is it possible that the user manual covers more than one model of your range and that they do a fully electrical version of it, and you have missed that bit in the instructions lol.
agree witrh sedgy. the kWratring for the cooker will include the gas equivalent on kw like they do with your gas bill, convert cu m to kwatts so you can't understand it.
Reply to cooker rating in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
