Just noticed a fault with my cooker as in the cooker will not switch off from the mains switch on the wall. Isolated the cooker at the CU and took the switch off the wall and investigated what was going on.
When opened I noticed that there was a live wire sitting loose in the socket and it has been melted, its red most of the way up and then black until the copper, which is also burnt.
Only issue I want to know about is the wiring of the wall socket. I don't have a multimeter as im saving up for a decent one, but im worried in case the loose live cable is still live and might be a feedback from something else in the circuit. Theres a fan switch on the other side of the cooker and its still working but haven't checked the CU to see if its fused separately. Below is a photo of the socket and the wire, I know where the wire goes to on the plug Im just unsure where it comes from. Is it the feed to cooker wiring? Thanks in advance, might just kill all the power in the house to be sure before cutting and putting it back in.
