Evening Gents and Ladies
So, moving a cooker switch that's over a hob 300mm to right.
Want the Load cable below surface to drop down to below work surface within zone BUT then end up back behind fitted cooker not the cabinet below. As subject, what do you guys do?
Would you do as I do for eg an intergrated Dish Washer that is under a sink, I run down below surface from the labeled isolator switch and then surface mount cable below the work surface for the horizontal 1m run to behind the machine?
TIA
Kind Regards
David
TIA
Kind Regards
David
