Cooker tripping fuse | on ElectriciansForums
Discuss Cooker tripping fuse in the DIY Electrical Advice area at ElectriciansForums.net
CTID71
Lancashire
Cooker heating element became misshaped. Tried to bend into shape and broke. Removed element and replaced. On switching the cooker off on occasion it trips the fuse. There was no issue prior. Could anybody advise why this is happening. Thank you
The crimps that fit onto the end of elements can be very close to the metal body of the oven when pushed back in… check they’re not bent, and touching the body.
Reply to Cooker tripping fuse in the DIY Electrical Advice area at ElectriciansForums.net
Oh I see. I will check that one as well. Thank you!
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
