Cooker | on ElectriciansForums
Discuss Cooker in the Australia area at ElectriciansForums.net
C
Cj24
Hi iv been called out to look at an electric cooker because it keeps tripping could a dodgy element inside the cooker make this trip bearing in mind it's bout 6 years old n never had a problem
Yes... If your certain it's not the circuit it's self then it is very likely to be the elements.
I have had this happen a few times with cookers and washing machines
Reply to Cooker in the Australia area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
