Cooker | on ElectriciansForums
Discuss Cooker in the Australia area at ElectriciansForums.net
C
Cj24
Cooker on a isolator then to a spur on 13amp fuse wired in 6mm, if it gets changed for a bigger cooker am I ok just eliminating the spur and use just a cooker outlet
Sorry that message dint make sense I was rushing, basically iv been asked how to upgrade a cooker because the existing cooker is fed from a 13amp fused spur and the new cooker draws more then 13amp, so am I ok getting rid of the spur and replacing with just cooker outlet, cable etc is big enough for new cooker going in
If as you say the cable is 6mm T+E then it will certainly deal with a 32 amp MCB, dependant upon installation method. So you can remove the FSU and make it a standard cooker supply IMO.
Hope that helps.
Reply to Cooker in the Australia area at ElectriciansForums.net
The pics you put up of the consumer unit are all good .....all circuits RCBO protected and as above swap the fuse out for a 3 amp
Thanks for replying
