B
BathSparks
A client wants to put gas hob ign, dishwasher, cooker and fridge freezer into grid switches. The main problem I have at the moment is the Tech Spec on the cooker lists 'Power (w) 40'. Surely this is the inside light bulb!. The cooker is a Zanussi ZYB460X. espares lists the main element at 2Kw and the grill at 1850w. All up that would be 4Kw. This translates into 18 Amps so should be OK on MK 20A with neon
Would this grid switch be regarded as satisfactory isolation? The cooker will be on it's own way in the CU, there will be a separate ring final circuit for all other appliances and sockets in the kitchen. Fusing/plugs etc. has not been decided yet but I am thinking along the lines using appliance plugs to single sockets, supplied from grid switch. They can be sited behind the cabs somewhere.
