Copper aluminuim wire???? | on ElectriciansForums
Discuss Copper aluminuim wire???? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Colne, Lancs
I was wiring i shower for a friend today and found what looked to be 10mm t+e but was 6mm and looked like it was silver on the outside and copper in the middle. It all tested out fine just wondering what it was and if its anything i need to be concerned about. Cheers all
Reply to Copper aluminuim wire???? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the UK the safe current for a cable is determined by considering how it's installed, eg under insulation, or buried in a wall, or in conduit...
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
