Copper equivalent to SWA armour | on ElectriciansForums
Discuss Copper equivalent to SWA armour in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
K
Kg85
[ElectriciansForums.net] Copper equivalent to SWA armour
Ive got a copy of this table, but not sure where it was derived from?? Has anybody else seen/used this table??
Throw it away it's wrong!! All SWA cables from 2 core to 4 core up to 95mm will comply with min CSA for use as the cables CPC. Main bonding requirements is a different matter, and should not be confused with sole use as CPC...
Copper has a conductance of approx 8 times that of steel...
Here use these two tables, tried tested and proven... lol!!
Blue = min CSA of cables SWA to comply.
(Red) = Cable does not comply.
Table for 70[SUP]0[/SUP]C Thermoplastic PVC SWA cables.
Conductor CSA
Minimum CSA of SWA to meet 54G
CSA of armour 2 core
CSA of armour 3 core
CSA of armour 4 core
1.5
3.4
15
16
17
2.5
5.7
17
19
20
21
23
35
24
36
40
41
44
49
16
36.1
46
50
72
25
36.1
60
66
76
35
36.1
66
74
84
50
56.4
74
84
122
70
79.0
84
119
138
95
107.2
122
138
160
120
135.3
(131)
150
220
150
169.2
(144)
211
240
185
208.6
(201)
230
265
240
270.6
(225)
(260)
299
300
338.3
(250)
(289)
(333)
400
403.9
(279)
(319)
467
Table for 90[SUP]0[/SUP]C Thermosetting SWA cables operating at 70[SUP]0[/SUP]C.
Conductor CSA
1.5
3.4
16
17
18
2.5
5.7
17
19
20
19
21
23
22
23
36
26
39
43
16
36.1
41
44
49
25
36.1
42
62
70
35
36.1
62
70
80
50
56.4
68
78
90
70
79.0
80
90
131
95
107.2
113
128
147
120
135.3
(125)
141
206
150
169.2
(138)
201
230
185
208.6
(191)
220
255
240
270.6
(215)
(250)
289
300
338.3
(235)
(269)
(319)
400
451.0
(265)
(304)
452
Just noticed, that table you posted is relating to ''Thermal Setting insulation'' cable operating at 90 C, which you can count on experiencing once in a blue moon. The thermal setting insulation cable table in my example, has beeen suitably adjusted to operating at 70 C. Not that you'll probably ever see a typical SWA cable operating even close to that sort of temperature either!!
That above table is like the wirenut table that's been doing the rounds since the late 70's, in being basically misleading, confusing, and pretty much useless for 99% of installations....
Anyway that's the reason why they are giving over the top values for min CSA to comply with table 54G.
Also and I know this should be bloody obvious, but make sure you still work out what the Zs is going to be at the end of the cable. Only really becomes an issue on longer runs.
The Armour is all well and good being a CPC, but if you can't meet disconnection times...
how would you go about calculating R2 of an SWA ?
Reply to Copper equivalent to SWA armour in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
yes it was a pee-take... I was commenting if someone was dumb enough to use earth clamps on armour, they might just be dumb enough to earth a...
totally agree
