- Joined
- Dec 28, 2008
- Messages
- 36
- Reaction score
- 5
i am installing fp cable for a fire alarm system grade a ld1 under house floor but it is inaccessible because floor board is lifted only every few metres. i need to use trunking to secure the cable that can be cut into short sections and then assembled into a long piece when under the floor. can i use 22mm copper pipe and join the sections with compression nuts. will this be ok with bs7671? should i cover the pipe with red insulating tape to distinguish it from plumbing? what other options are there?
