Cordless soldering irons | on ElectriciansForums
Discuss Cordless soldering irons in the Electrical Tools and Products area at ElectriciansForums.net
P
pennywise
Basically after one for heat shrink, just wondered which one others use. Have been thinking about a Weller.
I don't have a cordless one anymore. I used to use it so infrequently it was always dead by the time I needed to use it.
gas soldering iron, using small blowlamp nozzle, but care not to burn the sleeving.
Agreed would use a heat gun on larger shrink or not in a confined space, but when it's fiddly and singles in trunking or such like a Butane cordless with a deflector is alot more manageable.
PORTASOL PRO-PIEZO FLAME DEFLECTOR TIP (each) : Soldering Shop
Thanks lads .........though I can see one of my H&S head aches coming on here lol ................over here we don't use a lot of shrink, but I'd hate to let some loose on a cable and a naked flame lolk
yeah, malcolm, but we're all cowboys over here . that's why they brought in part pee.
I had a portasol gas iron about ten years ago that had about four different attachments , solder tip , hot knife , gas flame blow torch and a hot air blow torch . I cant remember how the last attachment worked but it was perfect for heat shrink .
I have had two of that exact Weller one, the first one I have had for years and was/is brilliant. I used it mainly for soldering, but did a little heat shrinking with it too.
The second newer one was not so good and a couple of times while using it as a soldering iron, a "ball of flame" shot out of the side of it near the tip, and nearly left me eyebrowless so I'm not sure I can give a full recommendation.
Reply to Cordless soldering irons in the Electrical Tools and Products area at ElectriciansForums.net
These may be ok http://www.farnell.com/datasheets/63120.pdf
Crimp or Wago inline connector, my preference would be Wago push fit...
