cbw
So time has come, everyone is sick of me asking them to drill me holes or borrow their cutter.
Bought a cheap high power drill today and now need a core bit @117mm what would you buy and what should I avoid?
THANKYOU!
I found the clarke ones from machine mart were pretty solid and long lasting if a little more pricey than the rest.
If you are intending to use a 117mm core bit I would avoid using a drilling machine that has not got a clutch as breaking body bits (wrist, arm etc) can occur if it jams. Also a drill with variable speed is good so you can run the core bit at optimum speed
i bought a cheap set of core bits from tlc that seem to work fine (around £60 if i remember right). did take their time on dampish redbrick though but i huess thet would have affected all the makes (had to keep removing the bit to clean off the (gloop, not dust) from the cutter and the sides of the hole.
UNG.....THANKYOU!!!! Cheap drill returned!!!
So, looks like I will buy the Clarke bit (However watching a macrist on flea bay)
Following your good advice........Which Drill?????
The makita is brilliant value for money it's got a really good clutch never been kicked by it.:D
i got a JCB Core drill set from City cracking it is , have got a dewelt cheapy i use and works ok but always wary of it jamming not fun spinning round holding the drill the milwakee core drill is as i have used one very good quality tools saves breaking your wrist i looking into buying a milwakee , there are loads on ebay
You obviously don't want to damage yourself
Talking to a couple of mates yesterday who run a hire shop they only hire out core bits as a kit with the machine so there can be no claim made against them for injury. They had a customer come in last week wanting to hire a large core bit only they refused the hire and offered the kit complete they asked the guy with him what had happened to him as his arm was bandaged and bruise on his forehead the previous core bit they owned had jammed!!!! no clutch / torque limiter on the drill so he got thrown and the core bit was a right off
I have the Makita 8406 machine which is specified for use with core bits had mine for about 10 years now
Makita: 8406 - Diamond Core Drill - Rotary & Percussion
cbw
Bury St Edmunds
Core bits
Electrical Tools and Products
cbw,
UNG,
