Corner lights and drilling | on ElectriciansForums
Discuss Corner lights and drilling in the UK Electrical Forum area at ElectriciansForums.net
london
Hi all
Just looking at installing some external corner lights. Wondering what the situation is with drilling the corner where the two walls meet for the cable entry? Will the corner not just break off when drilling?
Also, once in the cavity behind the external brick, does the cable need to be protected e.g flexible conduit maybe before entering into loft area?
Whether you break the brick depends largely on your technique and the state of the brickwork.
With luck the brick will be relatively soft and you will be able to drill the hole without hammer/SDS action. This should minimise the chances of it breaking.
Use a normal chucked drill with hammer action, will be much better for drilling brick corners, a SDS could break off the corner like a hammer and chisel
When you say external do you mean outside ie in the open or are you talking about the outside of a corner or the inside? A lot would depend on the hardness of the brick. Could you drill through the mortar between the bricks?
Reply to Corner lights and drilling in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
