R
richard1barker@
Hi All
I am going to be installing some high bay lighting which will consist of 3 x 400w metalhalide fittings so 1200w in total with runs of approx 60 meters in 2.5mm cable. I will be wiring the circuit via a 20amp contactor with a control circuit of a two way switch system to activate or pull in the contactor coil when swicthed on. Could anyone advise me on the size and type of RCBO to use for the lighting circuit and if when the switch is used to turn the lights on if it will trip one or both RCBOs in use.(One RCBO for light circuit and one for switching circuit)
