Correct isolation for sub main circuits | on ElectriciansForums
Discuss Correct isolation for sub main circuits in the UK Electrical Forum area at ElectriciansForums.net
J
jjnr78
Now, go easy its been a long tough month and I may be over-engineering my thoughts on this:
I was looking at an installation today which has the following arrangement:
main 3 phase service head in 1 location (assume TNS)
25sqmm 4 core swa to a 3 phase DB which then has single phase 63A cbs for 3 submain circuits (16sqmm 3-core swa) to 3 individual consumer units (for 3 shops)
Should the isolation at the DB be double pole rather than single for each consumer unit?
I think I'm over-thinking the double pole issue for 'maintenance purposes', but just wanted to be absolutely sure. there are lots of non compliant issues with the work, so it has me questionning everything about the last contractor's design and install techniques!
Reply to Correct isolation for sub main circuits in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
