C
Chector
Hi, I'm faced with an un-fused spur that goes to numerous sockets and light fittings, (they are mixed up i.e. socket, light, socket, socket, light, light). The spur is on a socket ring obviously. I would be grateful for advice on which of the following options other people would recommend or any other solution.
1. Put a 13amp fuse on the spur and remove all the light fittings. Create a new circuit for the lights.
2. Put a 5amp fuse on the spur and remove all the sockets. Create a new circuit for the sockets.
3. Put a 13amp fuse on the spur and connect all the sockets off the last socket t a 5 amp fuse an connect all the lights.
I think option 1 is the way to go, but I would value any advice. DIY electricians don't you just love their work!
