correction factor for discharge lighting | on ElectriciansForums
Discuss correction factor for discharge lighting in the Australia area at ElectriciansForums.net
P
p11jor
hi guys, just a quick calc here:-
4 X 400w rated lighting, is my calculation for this
1600/230 = 6.9amp X correction factor
Type C circuit Breaker.
thanks
phil
Reply to correction factor for discharge lighting in the Australia area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
