Cost for 5 downlights guys | on ElectriciansForums
Discuss Cost for 5 downlights guys in the UK Electrical Forum area at ElectriciansForums.net
sys3
Hi, just popped over from the Plumbers Forum and would appreciate some advice. I'm preparing a bathroom quotation that includes wiring up 5 12v chrome downlights with supply taken from existing ceiling rose fitting.
I'm drilling and fitting the downlights into PVC ceiling cladding and supplying the transformers and bulbs, so the spark needs to wire and connect everything up.
How much approximately for wiring 5 downlights so I can get my quote posted. My usual spark is in Ibiza and this is getting urgent!
80 notes seems very cheap who knows what condition original cable is in, how it is wired, if it needs replacing cosmetic damage occured, as many houses don't have rcd's is one needed.
too many reasons to do the job and get nothing back.
get a quote off an electrician that can see the job himself is my advice.
would a plummer give a quote without knowing size of property etc?
I have a quote done today for 4 D/L.
New C/U was done last week.
Quoting for LED IP rated downlights, obviously you are paying for these so allow accordingly.....
[ElectriciansForums.net] Cost for 5 downlights guys
  • [ElectriciansForums.net] Cost for 5 downlights guys
You need to get a spark to look at it, if the circuit has no RCD, then one is fitted and it keeps tripping/doesnt pass testing, circuit needs rewiring then you are talking a few more pennies then ÂŁ80 quid, that would be coming out of your pocket for not qouting correctly too remember!!!
If all is ok sticking 5 lights up (you supplied) it may be enough.
Reply to Cost for 5 downlights guys in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
