Costing running 3 phase motors | on ElectriciansForums
Discuss Costing running 3 phase motors in the UK Electrical Forum area at ElectriciansForums.net
Liverpool
Been asked to cost the running a number of motors . Was going two amp test each phase and multiple by line neutral voltage to get kWh . Is this correct .ta
Not quite. Multiplying current by voltage will give you the input kVA, not kW, because the two separate readings don't take into account the phase angle. It would be correct for a heating element but not for a motor, the figure will be too high by the power factor. Heavily loaded motors will be reasonably close, lightly loaded ones will give you a pessimistic figure. The only way to get the exact power that you pay for is to use a proper wattmeter.
Reply to Costing running 3 phase motors in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
