Could anyone give me some ideas on tools | on ElectriciansForums
Discuss Could anyone give me some ideas on tools in the Talk Electrician area at ElectriciansForums.net
Basildon
Hi I’ve just started working with industrial work and looking to stay in this type of work for as long as I can. Because I’m new to this my tools are mostly for domestic and commercial.
Could someone please give me some ideas of what tools I should get that will help me working in this field. The ‘must haves’
So I’ve got pliers and cutters anyway and got a file, grips already. But it’s more things like ratchet spanners and socket sets I’ve not got which I know I’ll need. I’m just not sure what else there is that will help me
One file? :)
I guess if you need to borrow something more than once buy it.
Other than that I have no useful advice.
The last time I worked in industrial we had to book the one cordless drill out of stores and straight back in again once done with it. :D
*Two swivel head 17"mm spanners.
*Bacho deburring tool.
*Centre punch spring loaded.
*Rat tail file.
*Fatherless File (flat/half round)
*Box spanner.
*Nylon draw wire.
*Cable rods.
*Ridgid (octaganol spanner for swa glands)
*Big flat head screwdriver for roofing bolts,driving home gland locknuts and levering over swa cables to line up cable ties.
2 slim jaw adjustable wrenches, junior hacksaw and Stanley knife for SWA glands.
17mm box spanner or channel sockets for Unistrut.
Full size hacksaw and square for cutting Unistrut, trunking and tray.
Flat, half round and round bas.tard files for cleaning up cut ends of Unistrut, trunking, tray and conduit.
10mm, 11mm, 13mm and 17mm combination spanners.
A couple of Podgers for knock in anchors.
Straight cut tin snips.
Draw wire for conduit.
Padsaw for cutting holes in plasterboard.
20mm, 25mm and 32mm holesaws (other sizes should be provided by your employer).
Chalk line, Laser, torpedo level and 5m tape measure.
Drill, impact driver, metal circular saw and small angle grinder.
Like any new job I wait till I get a feel for what I will be doing your colleges will give you a better idea as they are already established
Don’t go buying willy nilly as some of your most expensive tools, testers might walk before you get a chance to use them
Socket set, I have a spare one
You might find a hellermann sleeve tool will come in handy.
link
Also a good quality crimp tool for lugs (some sites may require ones that can be calibrated) and bootlace ferrules.
Ident applicator tool maybe, though I don't often use them myself. link
Bahco 9031P with reversible jaw for pipe fittings.
Soft hammer (most used tool except screwdrivers)
Wera Allen keys
1/4” socket set
7mm Wera flexible driver for jubilee clips
750g Facom hammer
Cold chisel (bearings, locknuts, everything else)
Tape measure
Knifed water pump pliers
Internet access for technical documents etc, and for taking pictures of things before you work on them.
Vernier callipers
Every size of spanner, pneumatic fittings can be funny sizes.
Safety glasses
Drill taps (spiral point are best in a drill I find)
WD40 - Tao lubricant, cleaning etc
Reply to Could anyone give me some ideas on tools in the Talk Electrician area at ElectriciansForums.net
Sorry for the late reply I found it very difficult to find work but I’m not sure if this was down to Covid and all the lock downs happening just...
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
