Could really do with some help! | Page 2 | on ElectriciansForums
Discuss Could really do with some help! in the UK Electrical Forum area at ElectriciansForums.net
stevie_sausage
On Monday just gone I carried out and Electrical Installation Condition report for the company I work for their were 13 circuits across 2 C.U 5 of which were 20a radials across a rcd controlled c.u for E7, the boards were wylex type and were fitted in Oct 2009 I did the test everything was in acceptable condition apart from a couple of C2/C3 notifications. sadly, the property caught fire that night, thank God the family was safe and got out! the customer was awoke by smoke alarms triggering at about 1 am. the boards have completely disintergrated ( I've not seen them only what I have been told) only remaining is copper no plastic enclosure and none of the plastic on mcb's etc, supplier has already removed the metering equipment . the next day my company sent a company who audit samples of our work that we carry out back to the property to re-do the test to check their results were in line with mine and that the test had been carried out correctly. They where. having spoken to my employers they want me to come back to work but obviously dont want me back on the tools until they have finished their investigation. However they are not going to get a forensic specialist in to determine the cause of the fire, though I want and would welcome them to, but they wont and this is where I am hoping some of you could possibly help me....
I am aware from looking over the last few days (hindsight is a wonderful thing) that around the 2009-10 Electrium gave a recall to faulty (wylex) mcb's that could and have in some cases caught fire, I have seen a few posts on-line where unfortunately they have, if anyone has come across them causing fires could you please post what happened and how fast the fire burnt through the board. the customer went to bed at 11pm monday night and as stated was awoke at 1am so this gives a two hour window for this to mainifest itself into a full blown fire, if it was surely you would have seen some smoke or s/alarm would have triggered in the hallway were the fuseboard is situated if it was 'slow burning' also customer would have surely got the legendary fishy smell throughout the day which would really have caused alarm with me only finishing the test at 1:50pm on the monday. I cannot rule out a mistake on my part unless forensics are brought in however having been in this industry for near 20 years I have never known 2x fuseboards go completely on fire & disintergrate within 2 hours after smouldering for 9 due to a loose connection ( please enlighten me if you have) again if it was loose connections would the power have not started cutting out depending on what was loose etc (testers said everything that remained was tight btw) I'm really at a loss here and could really do with some help as a bad name in this industry sure travels quick. thank you all.
Stevie, can't begin to guess how you are feeling mate, but on the bright side no one has been injured or killed. It may only have been one board which then caused damage to the other.
Easier said than done, but in your shoes I would just try to move on - you sound like a reasobable guy, so don't beat yourself up.
By the by, was there original paperwork for the 2009 install and if so, how did your results compare? Does look like a real chance of a Wylex fault.
Hope you get to the bottom of it for your own satisfaction.
Really does look like a case of wrong place wrong time. Really can't see both CU's going up, too much of a coincidence. Just hope that coincidence is the word in question for the whole issue. Good luck.
Hi mate a few years ago company that i was working at issued memos stating that they had problems with wylex units with thermal damage,we was asked to use a torque screwdriver to tighten,looks like you may have disturbed a loose connection who knows,easier said than done try not too beat yourself up over it.
Sorry to hear the bad news, I hope things work out for you, I suppose a loose connection could be one guess at what happened, sometimes disconnecting cables to test them and then reconnecting them may leave a loose connection, and under load, well anythings possible, however it may be total coincidence, I hope so pal, fingers crossed for you.
at a maximum it could only be 40a as the storage heaters where two small and two medium, plus a immirsion element which are about 3kw so if i were to say around 850w ea for two heaters and around 1500 ea for two medium heaters plus the three kw immersion I'm looking at about just under 34 amps. only thing i can feel could cause that would be the actual meter tails and
i checked them as part of the test.
I know what your saying Old timer but the thing is the auditors who did the retest said everything was tight on what was left of the board, but in your opinion have you ever known two boards to go up in less than 12 hours without their being forewarning etc thats what is baffling me Ive come across stuff thats burnt out due to loose connections etc and its been in for years also even when I have replaced fuseboards in the past its not uncommon to have found 25mm tails just fall out of the bottom of the isolator yet theyve done no harm for as long as the boards been in.
so, the auditors were last in?
buck stops with them then doesn't it?
more chance that they didn't tighten something back up after the retest, than that you didn't and they also missed it IMO.
The way I understand it normally to work is that the forensics people are called in by the fire service if there's any doubt as to the cause of the fire. Most of the time if they can't find a cause they put it down to an electrical fault BUT given that you carried out an EICR that day and everything checked out fine (and owing to the way you come across as a pretty conscientious guy) I doubt they'll just stick it in that box. If you were to make enough noise the fire service might be forced to bring in an investigator but this whole thing smells very fishy (no pun intended) to me. The place gets a clean bill of health then goes up in flames, there's something very wrong here and I doubt very much it's with you. Hope you get this sorted in your favour mate, keeps us informed as to how it pans out.
Reply to Could really do with some help! in the UK Electrical Forum area at ElectriciansForums.net
Hi I've nearly completed the 2357 NVQ. I'm just a bit stuck with Permits to work, Planned program of work and method statements. I work in the...
