Could really do with some help! | Page 6 | on ElectriciansForums
Discuss Could really do with some help! in the UK Electrical Forum area at ElectriciansForums.net
stevie_sausage
On Monday just gone I carried out and Electrical Installation Condition report for the company I work for their were 13 circuits across 2 C.U 5 of which were 20a radials across a rcd controlled c.u for E7, the boards were wylex type and were fitted in Oct 2009 I did the test everything was in acceptable condition apart from a couple of C2/C3 notifications. sadly, the property caught fire that night, thank God the family was safe and got out! the customer was awoke by smoke alarms triggering at about 1 am. the boards have completely disintergrated ( I've not seen them only what I have been told) only remaining is copper no plastic enclosure and none of the plastic on mcb's etc, supplier has already removed the metering equipment . the next day my company sent a company who audit samples of our work that we carry out back to the property to re-do the test to check their results were in line with mine and that the test had been carried out correctly. They where. having spoken to my employers they want me to come back to work but obviously dont want me back on the tools until they have finished their investigation. However they are not going to get a forensic specialist in to determine the cause of the fire, though I want and would welcome them to, but they wont and this is where I am hoping some of you could possibly help me....
I am aware from looking over the last few days (hindsight is a wonderful thing) that around the 2009-10 Electrium gave a recall to faulty (wylex) mcb's that could and have in some cases caught fire, I have seen a few posts on-line where unfortunately they have, if anyone has come across them causing fires could you please post what happened and how fast the fire burnt through the board. the customer went to bed at 11pm monday night and as stated was awoke at 1am so this gives a two hour window for this to mainifest itself into a full blown fire, if it was surely you would have seen some smoke or s/alarm would have triggered in the hallway were the fuseboard is situated if it was 'slow burning' also customer would have surely got the legendary fishy smell throughout the day which would really have caused alarm with me only finishing the test at 1:50pm on the monday. I cannot rule out a mistake on my part unless forensics are brought in however having been in this industry for near 20 years I have never known 2x fuseboards go completely on fire & disintergrate within 2 hours after smouldering for 9 due to a loose connection ( please enlighten me if you have) again if it was loose connections would the power have not started cutting out depending on what was loose etc (testers said everything that remained was tight btw) I'm really at a loss here and could really do with some help as a bad name in this industry sure travels quick. thank you all.
Remember 95% of MCBs or RCDs are made in either China or India and yes we hope the importers ie the CU manufacturers are doing quality assurance testing but me thinks not . Thing is if it is traced to faulty equipment fine but if these incidents become more common then they will do something about it
Well well what were we talking about and now MK doing a recall Deary dear he we go again
I got called out two weeks ago to a property that had a fire in a sector board (part of the electrium group recall), fire brigade had put it out, it seemed to start at the base of the mcb above the busbar connection,
probably the busbar was of the forked type....and was not properly located/secured by the terminal screw.....
got to watch it with them forked busbars...
- - - Updated - - -
an inspection mirror on a little stick will give the game away...
went to job of mine in old pump house ,water dripping on suppliers meter and cutout caught fire leavin nothing.was lucky nothing flamable,elecy board jus turned up and changed it.was thinking there equipment didnt disconect properly and in different circumstances whole building could have gone up and they would maybe pin on me.suppliers meters were removed were they below yer boards.
Reply to Could really do with some help! in the UK Electrical Forum area at ElectriciansForums.net
Hi I've nearly completed the 2357 NVQ. I'm just a bit stuck with Permits to work, Planned program of work and method statements. I work in the...
