B
Benn
At work we have been installing wireless thermostats, Honeywell ones, and I was thinking Id like one at home. But I have little experience with my system that is at home. From what I know I have the following :
Back Boiler
Pump
Tank in the loft
Thermostat on the stairs
Time clock, either Hot water or Hot water and Heating options.
Double surface backbox with all the connections and blanking plate.
Basically a gravity fed system I think.
I may be being a thicko but you only know if you have experienced it before. I want to know hot the system works and whether I would be able to install said wireless thermostat.
The way we do it at work is when there is a combi boiler installed we just run a cable to feed the spur which feeds the wireless controls wired with a 5 core flex to the boiler. (just for infomations sake)
Back Boiler
Pump
Tank in the loft
