Could someone please tell me what these are called/where to find them. | on ElectriciansForums
Discuss Could someone please tell me what these are called/where to find them. in the Electrical Tools and Products area at ElectriciansForums.net
flex_m
United Kingdom
I had to take a switch off the wall and when I came to replace it the screw will no longer bite, it appears the thread in yellow bit shown in the picture has warn down. If anyone could let me know what they are called so I can replace it I will be very thankful.
Cheers
[ElectriciansForums.net] Could someone please tell me what these are called/where to find them.
No idea what they're called, I doubt you'll find then for sale as a part on their own.
Find yourself a 5mm rawplug and trim it with sidecutters so it can be shoved in the oversized hole. If necessary sharpen the screw slightly to help it make a new thread. Bob will immediately be your uncle.
plastic lugs. used in the 60's when there was no cpc on lighting circuits. just cut the box out and fit new box.
I have come across these a while back , they are imperial fittings and will take the slightly larger imperial screws , there should have been imperial screws already in use , if not get some , they are slightly larger diameter , not sure where you get them , I always save mine up when I remove old fittings,,
You'll probably get imperial or whitworth screws from RS Components.
DOUGH!! Several days and an eager labourers broom passed before I needed to refix it.
Lesson learnt!
3/16" Whitworth or 2 B.A. maybe? Both are close to 5mm.
Reply to Could someone please tell me what these are called/where to find them. in the Electrical Tools and Products area at ElectriciansForums.net
This is an RSS feed of thread: Pura shower head - too much weight for a tiny thread Content of the thread: Hi there, Hopefully someone will be...
