Countdown timer switch stopped working | on ElectriciansForums
Discuss Countdown timer switch stopped working in the UK Electrical Forum area at ElectriciansForums.net
Halifax
I have a countdown timer switch hooked up to run my washroom fan. It stopped working all of a sudden.
I replaced it with a regular switch and the fan worked.
I took the old timer switch and hooked it up to another different washroom fan, and the old switch worked.
What am I missing?
A poor connection that you have fixed when switch was changed
Or a faulty switch brought back to life with the movement of replacement
  • [ElectriciansForums.net] Countdown timer switch stopped working
Mmmm! Your profile gives your location as Halifax, but I'm beginning to think you're nowhere near West Yorkshire. There must be another Halifax somewhere.
A quick Google search shows hat there are near identical versions of this, one requiring a neutral connection and one not, with the version requiring a neutral having MN tacked to the end of the part number.
Reply to Countdown timer switch stopped working in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
That doesn't make sense it is a completely new timer so needs connecting as per the instructions for this unit. Has the safety cut out on the...
