P
PvNewbie
Hi
I'm looking at a roof which is counter battened which is causing me some confusion, so perhaps someone can help me out. Basically, if I put my roof hook above the horizontal batten, then it will sit on the lower vertical one and 'rock' as the batten isn't wide enough to support the hook properly. I probably wouldn't be able to screw properly through the batten into the rafter anyway as it is too thin and will split!
Has anyone got any suggestions?
