Counter wiring issues | on ElectriciansForums
Discuss Counter wiring issues in the Talk Electrician area at ElectriciansForums.net
Kj14
United kingdom
I'm struggling to get a timer to work. It's a red lion pax r, and I'm using a proximity sensor as the input to count so that every time it makes it counts. The manual that comes with it hasn't helped
Is it a counter or timer ?
[ElectriciansForums.net] Counter wiring issues
Could you provide details of the proximity sensor, in particular its output which you have connected to the counter. I need its name and model number so I can google it. Also, how have you have connected it to the counter at the moment?
proximity sensors come in many flavors(hall effect, capacitive, and optical style) and have different outputs,(normally open and normally closed(digital) and variable resistance(analog))
more info on the sensor is needed and preferably a drawing of your circuit. this can give us an idea of whats going on
Reply to Counter wiring issues in the Talk Electrician area at ElectriciansForums.net
Hi, I have a ‘05 Megane ii 2.0 with a f4r, and I was wondering if anyone has any info regarding wiring a bee r rev limiter up to them I only need...
M
This old thread has a short video which seems to reinforce your description (see post #2) but doesn't help much...
