M
Mark_Burgess
Had to replace double socket outlet today on a circuit I installed last year.
This had a four way extension lead plugged into it, and that was pretty much overloaded with fan heaters and a printing machine.
Whilst my customer was near to the socket, the printer just stopped, no power. They noticed a smell from the plug and tried to turn it off at the socket and it would not switch off, the socket could not be pulled out.
Anyway, I removed the socket today and replaced it, the socket had melted in back by the neutral pin, after I got the plug out of the socket (The pin plastic insulated bit was melted/expanded) it was clear that the neutral cable termination into the plug (not a moulded plug) was absolutely fine.
Now, I am thinking there was an overcurrent issue and the fuse should have blown but didn't.
The fuse looked legit and was 'Mercury' branded, I forgot to bring it home and will collect it in the next few days to weigh it.
What are your thoughts?
Counterfeit fuse?
Duff Socket outlet? (Crabtree twin socket Double Pole)
Counterfeit fuse?
