Couple Questions | on ElectriciansForums
Discuss Couple Questions in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
njcuk
Hi Guys,
These maybe fairly obvious but interested in knowing the following.
How much ( in KW ) can a two phase system take? ( Family member researching in a 49kw system ). How many KWs is it before you have to go accross to two or three phase?
Also, saving electricity. How simple is it to store electricity in large batteries just as a small back up? What are the potential problems?
And what is the average wattage loss per meter?
The first question doesnt make much sense.
The second question is better! Storing power in batteries is achievable, but the cost of batteries has shot up and they require regular maintenance plus space!
think he means how many kw is available on a single phase install. but, domestic or industrial? on a domestic it's 100A, whick is 23kW.
If you want to know the maximum size of pv generation you can connect to the grid without having to pay for reinforcement then the only way to be certain, above the standard G83 16A per phase, is to ask your DNO.
Reply to Couple Questions in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
I agree, it is a bit unfair when they change the rules. however, as a nation out usage patterns are changing and the most cost effective tariffs...
