Am I right on this, as far as I can fathom the regs state that the CSA of the CPC should be equal to the live conductors but T&E are not required to conform, so does that mean if a circuit is wired in singles in plastic conduit then the rule applies, but if wired in steel conduit and the conduit is earthed then the cpc size can be reduced accordingly, and yes I understand that the appropriate tables will provide this info but what the take on this in practice
Pict
Pict
