T
Test Probes
Hi all. I'm testing a new instaulation (care home) and have come across a problem in a lighting circuit and both my self and the tech can't make any sence of it. Unfortunately, the fittings are in place. The normal readings would be about .30 to .54 ohms on the cpc of the circuits I've tested. I've done almost all of the circuits and now this comes up. My cpc is 157ohms. How can this happen? I've checked earth conductors and have assumed there is some parallel paths. So I'm now thinking there may be a line conductor problem. :confused5:
