UK Crabtree Ceicon 3p DOL and overload
HI, have anyone got a wiring diagram for a Crabtree Ceicon 3phase DOL with overload? I have a couple salvaged from working machines that are no longer used, but with all the wiring removed! I've tried to rewire the overload to the contactor with conventional connections using various other manufacturers diagrams and my bad memory from previous work with DOL's, and can get the machine to start ok, but the stop/trip does not work when livened up, although when dead testing it with a simple continuity test, it works perfectly. I've tried all sorts of configurations but same thing happens when hooked up? I have 2 of these and get the same result on both? I've searched online and there are dozens of different makes, but I cannot find a Crabtree Ceicon diagram? Surely they cannot be massively different from all others make? Any help would be appreciated!
