T
tarshmomp
Hi all,
First of all, i'm sorry if I am not permitted to post here as I am most definitely not an electrician (so excuse my ignorance)
Since yesterday, I have not been able to use any sockets, due to my RCCB Split-Load tripping. If I switch the "sockets" switch on my consumer unit, it will take about 3 seconds and trip the RCCB.
I went through all individual sockets I could find, taking them out 1 by 1, but no luck. Eventually, I switched off the water pump, and switched the "sockets" switch back on and, the main breaker didn't trip! however, soon as I turned on the kettle and started boiling a brew, it tripped.
I thought it could potentially be a problem with the main breaker, but I can't seem to find one the exact same anywhere.
So, what I wanted to ask was do you think, in your opinion it could be this causing the problem? and if so, where can I get them from.
Thanks in advance for your help!
