Create a safe switch that will trip RCD | on ElectriciansForums
Discuss Create a safe switch that will trip RCD in the UK Electrical Forum area at ElectriciansForums.net
Dean Longstaff
So hi everyone, i have alot of electrical items in my room upstairs. And if anything were to fail i would like a switch that would turn everything in the house off. If i were to have a red emergency stop button (normally open) and connect it to a plug so that the ground wire and neutral connect when the button is pressed, would this trip the RCD in the fuse box? Also would it be safe? If not is there any safe ways of doing this? Thanks
Just put a emergency stop switch before the wiring coming in the room
Work benches and workshops have a emergency button
I guess it's 2P2T normally closed switch
Mm sounds like you are trying RCD tripper... I don't think should talk about this as people will try and trip the RCD at work or in shopping
Could trip the RCD with computers hooked up.. If you wanted
Okay, so if i didnt work, or if it did work is it still safe connecting neutral wire to earth wire?
Generally it is not a sensible or safe thing to do. If the RCD is working correctly then it will detect this fault and operate before it becomes dangerous, but RCDs aren't the most reliable of devices so you may get in to a situation where you are introducing a potentially dangerous fault and making the situation worse.
What exactly is it that makes you think an emergency stop is needed?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
"So hi everyone, i have alot of electrical items in my room upstairs. And if anything were to fail i would like a switch that would turn everything in the house off."
I think the item you are thinking of is a consumer unit.
Reply to Create a safe switch that will trip RCD in the UK Electrical Forum area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
