create branches along the 220 V power cable | on ElectriciansForums
Discuss create branches along the 220 V power cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
igurov
Hi,
we have a 100 m 220V ground power cable and at regular intervals we want to make branches of length say 5 m. My question is how do you do this correctly and in safe way. Just clip the cables and connect the wires or is there a safer way to do this?
Best Regards,
Iliya
Hi,
Best Regards,
Iliya
You will need, made for purpose epoxy or heat shrink T or Y joint kits, suitable for underground installation.. Using the same size cable for your branches, as the main cable run. There is no other safe method that i know of, to facilitate your requirements.
Reply to create branches along the 220 V power cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
It might be ok
