Crimps inside the CU | on ElectriciansForums
Discuss Crimps inside the CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think I have gleaned sufficiently from other posts that it is acceptable to use good quality inline crimps to extend cables for terminatingwithin a newly installed CU. Invariably,for 2.5mm T&E and 1.5mm T&E these crimps will be red in colour. I ask the experienced electricians on this forum: is it best to cover the crimp with suitably coloured insulating tape or left as it is?
Blue for 2.5mm and Red for the 1.5mm.
Insulation tape is best left in the wholesalers - pointless. You can heat shrink if you like but no need
No, ...Never use PVC tape on crimp connections always use heat shrink!!! For an even neater job you could use bare crimps with 2 layers of heat shrink to insulate them. Or you can buy heat shrinkable insulated crimps. For aesthetics sake, i always like to see the appropriate core coloured heat shrink over crimp connections...
If you use the uninsulated ferrules crimped with a decent indent crimper and put 2 layers of heatshrink over it makes for a more streamlined joint.
[ElectriciansForums.net] Crimps inside the CU
Reply to Crimps inside the CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
