I could do with a bit of advice on how to and why we should cross bond to the pipes that enter and exit a central heating boiler. Should each of the water pipes be cross bonded. Should the gas pipe be bonded? I understand that that the incoming services must be bonded as they enter the building, direct from the main earthing terminal. The rest isn't quite so clear. Could somebody help?
