R
Richard3009
To obtain the readings R1+RN/4 and R1+R2/4
at each socket outlet, when the crossover connections have been made at the CU.
If using a modern all in one tester like an MFT1552, is this test swift using a 3 pin plug or are you having to use probes to select the particular pins at every socket.
