CT & VT neutral earthing | on ElectriciansForums
Discuss CT & VT neutral earthing in the Australia area at ElectriciansForums.net
Y
yesukannan
Hi all,
why in Current and Voltage Transformer the star point is earthed. that too checking for single point earthing what will happen if there is a duplicate earthing.
thanks
alaguraja
Hi all,
thanks
alaguraja
If the star point is not earthed, it will not be at 0V and then the neutral will not actually be 'neutral' and if a line-earth fault occurs, it is almost impossible for any protective device to operate on a primary fault.
Reply to CT & VT neutral earthing in the Australia area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
