Ctec smoke base | on ElectriciansForums
Discuss Ctec smoke base in the UK Electrical Forum area at ElectriciansForums.net
R
Roy Catherall
Hi
Conventional
I have four detectors L1L1 L2L2, eol last one.
Smoke test red light on detector on but it doesn't trigger the panel and sounders.
Is there a further resistor required anywhere on the run.
Silly question…. But is it on “silenced”
Usually, on a detector test, the alarms dont sound… just a visual indicator. To stop buildings being completely evacuated on every test.
An alarm test is done at a predetermined arranged time…
It doesn't trigger the fire alarm lights etc in the panel the sounders work when I test the call point on zone 2
Reply to Ctec smoke base in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
