d3jpt
I am changing my home CU for my NIC inspection. At the moment i have a rewirable fuse CU in a 1960's house so thought its about time its changed. On initial inspection everything seems in order, ok it all need to be brought up to 17th standards and none of the lighting circuits have an earth but it doesnt look too bad.
One thing is though there isnt enough slack on the cable and every circuit needs extending to fit inside the new CU. My question is as it needs to be inspected is what would you use to extend the cable for each circuit? I was tought that red/blue/yelllow butt connectors are fine but just not really sure about these. what would the NIC say?
cheers for any advice
