CU change in cupboard under the stairs | on ElectriciansForums
Discuss CU change in cupboard under the stairs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Miketwinny
[ElectriciansForums.net] CU change in cupboard under the stairsHi
I want to change the old fuseboard in the cupboard under the stairs to a new CU.Would I need to reposition it to comply with part M build regs for easy access or would a straight swap be ok.
Just swap it where it is. If it were a new build then Part M would come into play. Consider providing an emergency light in the cupboard, easy enough to do and provides piece of mind.
Is it just me or should the grey L & N cables connected to the j/boxs after the isolator be the same size as the cables coming out of the isolator then only reduce down in size when they are fused to the relevent sizes? or is my eye sight going...
one would assume that OP would rectify that on a CU replacement.
most economy 7 supply cutouts often have 4mm double insulated tails coming straight from the henley blocks , no other protection for these conductors other than the 100A main fuse :)
DNO dont have to comply with out regs ! lol
although in this pic it does not seem those tails are associated with the supply company as they are after the main switch
Reply to CU change in cupboard under the stairs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
HI, I'm a director of a freehold building which is 4 stories (one flat per storey), with a basement flat with its own separate entrance down...
