CU change - some T&E cables too short | on ElectriciansForums
Discuss CU change - some T&E cables too short in the Australia area at ElectriciansForums.net
N
ngoodson1969
Hi guys,
The above is due to there being 2 existing units.
Would the best thing to do be to terminate all in an adaptable box then onto the new CU?
Cheers
Nick
Reply to CU change - some T&E cables too short in the Australia area at ElectriciansForums.net
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
Recommended Sponsor News
Hi everyone,
