Cu change will garage be covered...? | on ElectriciansForums
Discuss Cu change will garage be covered...? in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Got to upgrade CU soon, old wylex rewirables.
Garage also has a liitle 2 way wylex rewirable in there, is there any reason why I would have to change this as well ?
Thinking it will be covered by the RCD back in the house, but also thinking there might be something I've missed though ?
Thanks Sy
Assuming the submain is for lights, power in the garage, no reason you should. Really depends on what you want to/have quoted for. I would at least check out the distribution circuit to the garage CU though and either way make it clear what you're doing/not doing for the job. Clients can be "funny" sometimes when they expect they're getting something :D
Reply to Cu change will garage be covered...? in the Australia area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
those old mk rcds are very fast the figure you have quoted is the maximum allowed not the typical times,I have seen mk ones trip at 9 ms , the...
