CU Change with economy7 | on ElectriciansForums
Discuss CU Change with economy7 in the UK Electrical Forum area at ElectriciansForums.net
PAD66
Alsager, Cheshire
Been to look at a consumer unit upgrade at flat with two storage heaters on economy 7. I have two questions that i need help on
1. Do I need to change the board for the two storage heaters and the immersion or can they remain on the existing board without RCD protection, The householder is not sure if they intend to keep the storage heaters in the future
2. An electric shower has been fitted at some point on its own fuse, the thing I dont understand is that the Neutral is feed from one meter and the Live from the other. I intend to disconnect this and put it on the new board not on the economy 7 side
thanks
Reply to CU Change with economy7 in the UK Electrical Forum area at ElectriciansForums.net
What makes it a lack of space? I’d say to the customer to dismantle a cupboard or whatever to creat the space you need for the extra equipment...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
