cu change | on ElectriciansForums
Discuss cu change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Peter Woodford
just wanted to check a few things
woman wants her cu changed and moved am i right in saying the new tails into cu can only go up to 3 metres. Also the cables will need extending is this ok to crimp and but in trunking up wall as woman wants cu moved up at high level in hallway.
cheers
tail length varies from dno usually 2 to 3 metres then you would need to fit fused isolator in, crimping cables is fine for extending, just heatshrink when crimped.
Reply to cu change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
