cu change | on ElectriciansForums
Discuss cu change in the UK Electrical Forum area at ElectriciansForums.net
M
martinsayer81
quick question
if i was changing an old fuse board to a new c/u, and i was installing 3 new circuits,
would i have to fully test all the old wiring before connecting it all up?
and what if the old wiring keeps tripping the new rcd?
how would you guys go about it??
Yes you would have to test all the circuits as you are making changes to them.
There are loads of posts on here telling you how best to do pre-check testing or you can always fit an additional board for your circuits then if the client does not want to pay for any corrections to failed circuits.
I've learnt the hard way about not testing before hand. You need to test before hand to identify any problems that will arise when installing any form of RCD board on an old installation. Any faults identified need to be presented to the customer and they then decide if the want to proceed as any rectification works will cost more money.
If you just jump in and change the board and things start to trip you'll get the old 'it was fine before you touched it' comment, playground rules apply.
so you're saying that when i turn up to look at a job for the first time, i should open up the fuse board and start testing it??
You have to concider the fact your quoting a days work with the full testing so 10 mins to highlight now major problems is minor and mainly for your benefit as your the one having the agro finding the faults later and at who's cost if you never quoted it.
This is one of the things that separate a qualified person from a cowboy.
I always quote this as 2 days work, just not enough time in the day to do a full CU change & full EICR that needs to be completed as you are affecting all the circuits. Even though the wiring may be in poor condition before the cu change. As i see it by changing the CU and effecting all circuits, thus being responsible to at least report the condition of all circuits
but i wouldnt be responsible for livening up an existing circuit that has a 230V fan in zone 1 of a bathroom, would i?
in that situation would i advise the customer of the dangers and make a note on the certificate
When I survey a CU change I do global IR test and Ze/PFC/PSSC BUT I do not pass this on to the customer for good economical reasons ie I am not here to help £200 CU man get a job
Not quite with you on this.
If you do tests and find all's well, what do you tell the customer?
Generally,though, I've always been a bit mystified about the recommendations to do a full EICR first.
If you find several or lots of faults and tell customer it'll cost so much if they want new CU how do you get them to pay at least £150 for the EICR if they decide not to pay for repairs and new CU after all?
Got to be honest here, when you go to look at a CU change what else are you looking at other than the circuits you will be re-connecting ? afterall the old board is going. That is the whole point of the exercise to enhance the system and find out what needs correcting, afterall you will be the last sparks who touched the place if there is a fire or worse. Did you think they may knock on someone else's door if you made live a circuit that killed someone later. Bit harsh i know but you must see the bigger picture.
Reply to cu change in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
