CU wiring too short for new board! | on ElectriciansForums
Discuss CU wiring too short for new board! in the Australia area at ElectriciansForums.net
F
FAA Greenie
Hi Guy's, first post for me.
I have a client who has asked me to replace a rewireable fuse board for an 8 way split load board. No problem. Until I look into the existing board to find that the spark who fitted it took great pride in ensuring that the outgoing supplies were measured to the millimetre (Thou's of an inch to you oldies)!! to fit into the fuse terminals. Obviously this leaves me no spare wire whatsoever to get these wires into a modern 17th edn board. I have done prelim testing on the installation and all the circuits are fine so there is no reason to rewire any part of the installation. The existing fuseboard is in the garage and the client is unwilling for me to dig out and chase new cabling to the nearest sockets/lighting accessories inside the house to extend what i have to work with.
What is the easiest, safest, legal, easiest on the eye way to extend the little stumpy bits of cable i have available to give me something to work with?
I can, possibly move the board down a short distance, currently the circuits feed into the rear of the existing board.
Thanks in advance, if there is an obvious answer, i accept ribbing and critisism very well....
no ribbing needed mate. if you dont know ask! :)
i would get a din rail in a suitable ip rate box and do them all from there. all nice and neat and no stress not a crimp or heat shrink in sight :)
[ElectriciansForums.net] CU wiring too short for new board!
something like the one above
can you give the less inexpierienced a quick how it works phil.... are you balld phil
Use a combination of high towers method with phils box. Din rail box where the old cu was then crimp/wago extend through trunking to new cu if you've got the space.
Ps Phil's not bald, he has a full head of hair. His avatar pic is not that far off ;)
Reply to CU wiring too short for new board! in the Australia area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
